Hey so i got this tablet to fix and im trying to salvage the lcd. U guys see anything wrong with flat cable and if u do where.
View: https://imgur.com/a/XPQbuDK
I applied a bit of solder on them dont think they are problem. Also a tape that was covering those components on back looked burned could it be that component. Also i forgot to mention at a time i could have moved ribbon cable and got color back which was weird.Use a powerful magnifier if you have it. Check all those inflexible parts on the ribbon - those 2 strips of solder, the component(s) soldered onto the other side. That's likely where there could be a break in continuity - where the rigid components meet the thin, flexible copper traces.
