specs
(following items are 1year old +)
CPU: i5 4590 3.3ghz
GPU: MSI R9 280 3GB OC GDDR5
MB: MSI H97 gaming
PSU: 500W 80+ (GOLD)
SSD: 128gb
(following items are 4years old+)
HDD: 1tb
RAM : 2x4gb
CASING : lancool k59
Problems:
1) Heat trap inside pc (can felt the warm air coming out when opening casing)
might be the "back" fan not functioning very well
2) unknown loud noise when playing graphic demanding game
not sure isit from cpu/gpu fan or from my old hdd
plans:
1)install water cooling
2)change casing
3)change hdd
4)might change GPU to nvidia and support ASUS 😀
Games: BF4(high settings 1080p)
GPU temp: highest hit 81degree
CPU temp: highest hit 70++degree
FAN speed: average 1300rpm~1500rpm(auto);
manual increase fan speed by 60%~80% when gpu temp hit 75degree<
plan to change to gtx770 to play in ultra settings (unsure isit good enough)
unable to check cpu rpm
need advice on
1) suggestion about which water cooling to buy and how to install it
2) suggestion about which casing to buy
3) ideal gpu to play BF4 in ultra settings ( might use for another 2 years)
or should i remain on R9 280
Thanks in advance
CPU: i5 4590 3.3ghz
MB: MSI H97 gaming
SSD: 128gb
HDD: 1tb
RAM : 2x4gb
Problems:
plans:
2)change casing
3)change hdd
need advice on
Thanks in advance
