Ok heres my problem I cant over clock my phenom ii x2 550 be over 3.4 ghz or it crashes in prime95 I get a blue screen error memory crash heres my system
Phenom ii x2 550 be
Mobo GA-MA770t-UD3p rev 1.1
memory g.skill ddr3 1600 2x 4gb F3-12800CL9D-4GBNQ have it set at right timings 9-9-9-24
850 watt azza power supply
His 4670 video card
Windows7 64bit
I have a Thermaltake Fan for my Cpu runs at 27c idel and only goes up to 34c after 2 hours of prime95 I have unlocked this CPU with the f5 bios and have ran it as a 4core in prime95 temps idel at 31c however went up to 49c prime95 after 2 hours no errors however I don't really need 4 cores just doing some low ended gaming (this my SC2 comp should be out by July I hope) so I was just going to run it as a 2core at 3.9ghz but I cant even get over 3.5 with out crash I have ran memtest86+ 4 pass 0 errors like 4 hours of test
I have put cpu voltage all the way up to 1.5volts just to try and run 3.4ghz and added nb volts by .25 don't really know what to do at this point my system runs very cool system temp 28c cpu temp around 30 when I play a game and the videocard is 40c using a azza 910 case had to remove the rear fan the thermaltake CPU Fan is massive my top fan still in so still got 2 fans putting air in and 1 out runs very cool
BTW using easytune6 to look at my temps came with the mobo speedfan shows the same temps 1degree off so I think its right on
I'm thinking that overclocking my cpu messes with the amd memory controller so I might just have to do a very light overclock kinda upsettin9
Phenom ii x2 550 be
His 4670 video card
Windows7 64bit
but those are the numbers
