[SOLVED] Need some help with this memtest86 results.
May 29, 2021
Hey guys, so I just got a BSOD this morning and it mentioned memory management, so I decided to do a memtest and got these results. I am kind of lost atm does this mean my cpu is the problem or the ram is the culprit?
My specs are CPU: 10900k, Ram: Corsair vengeance 32gb 3200 MHz, motherboard: Asus z490 e gaming, GPU: Asus Tuf 3080 OC.
Picture of the Result: https://postimg.cc/Tpq343d8
It's only a single bit error, so I would reseat the modules and retest. The cpus it is referring to is the cores that were running when the error occurred. Not sure what use it would be unless someone had a schematic of the entire motherboard with all the traces.
