T Tylerstafford Reputable May 8, 2014 1 0 4,510 May 8, 2014 #1 Hi, I am looks to buy a gaming computer between the price of £550-600 not including a monitor, keyboard and mouse. I cannot build a computer so would anybody suggest any good computers for my pricing range or web links, thanks
Solution plaintuts May 8, 2014 if you can't build your own computer, then best advice is to just go with branded pc's that will fit your budget.
plaintuts Admirable May 5, 2014 2,855 0 7,460 May 8, 2014 Solution #2 if you can't build your own computer, then best advice is to just go with branded pc's that will fit your budget. Upvote 0 Downvote Solution
