Need some LED input
Towelieyee
Okay, I was thinking about replacing the white LED fans in my case with something red. I was looking at these: http://www.coolermaster.com/product/Detail/cooling/case-fan/jetflo-120.html and thought they seemed nice. I then came across this: http://www.amazon.com/NZXT-CB-LED20-BU-2-Metres-Sensitivity-Sleeved/dp/B0046Y5Z5G/ref=sr_1_1?ie=UTF8&qid=1384437686&sr=8-1&keywords=nzxt+sleeved+led+kit and thought it looked good. My only problem is, whether I should go with the fans, the strips + non-LED fans, or both, the fans and strips. My concern with going with both would be that I'm not sure if they would turn out to be the same shade, and even if they were, would it just be overkill? Any input would be much appreciated. Thanks in advance.
