Need some suggestions for build editing and gaming pc and running smooth..
Rickodecoro
29
This is the specifications :
Power Supply : Corsair AX760i
Motherboard : Asus Maximus V Extreme
Processor : Intel Core i5 3570K
Memory : Corsair Vengeance Pro 32GB 4x8GB DDR3 1600 PC3-12800
Graphic Card : Asus NVIDIA GeForce GTX 770
This is enough for editing using adobe cs3 master collections in windows 7 ultimate 64 bit running with smooth graphic? and this is enough for playing battlefield 4 using ultra setting running with smooth graphic and get +60 fps? oh ya i'm use a single monitor and 1920 x 1080 resolution, i'm not use multi monitor for this specifications.. thanks before 😉
With a good cooler and moderate overclock the 3570k is still very capable. I would not bother with an upgrade yet.
Just bear in mind that even an i7 will have some frame dips below 60 FPS in BF4 on ultra. It depends on the map, players, amount of activity and VFX on the screen at the time.
i have corsair h60i for cpu cooler and replace a fan with corsair pwm high performance, that's enough? or i need to upgrade processor to higher series? i'm just want to enjoy my work and refresh my brain with playing games without bad performance, tell me if you have some suggestions to upgrades the specifications..
