• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Need suggestion on Power Supply
bala_4370
Commendable
Apr 7, 2018
18
Hi,
Need valuable suggestion on selecting the right Power Supply for my Computer. Have chosen few based on my Budget and I can go up by few more 100's if that really counts.
System Spec's
ASUS Prime B350M-K Board
Ryzen 1300X Processor
16 Gigs Corsair Vengeance RAM
1050 TI 4 GB Graphics Card
1TB HHD
Choice's I have made on power Supply
Antec Atom V450
Antec BP450P Strictly Power
Antec VP450P
My budget was around 3K
The wattage you need is mainly determined by the graphics card you will use.
Here is a handy chart:
http://www.realhardtechx.com/index_archivos/Page362.htm
Your needs would be satisfied with as little as 350w.
But to allow for a future graphics upgrade, it is best to buy stronger.
The psu will only use the wattage demanded of it regardless of the max capability.
450w is about right.
As above, do not buy a cheap psu.
Antec is generally ok, but some are better than others.
If you can, buy a t least a tier 3 unit from a quality list such as this:
I do not know your pricing.
Reactions: bala_4370
bala_4370
Commendable
Apr 7, 2018
18
Thanks,
Have one more question.
My MB has ATX 8 pin socket, can i connect 4 Pin since most of the PSU comes with 4 pin.
