Need Suggestion To Clean Monitor
shedlight
22
Hi,
I got Dell UltraSharp U2412M monitor and I'd like to know how to clean it's screen?
Can I clean it with soft cotton cloth (old tshirt or towel) or is there any solution available in the market?
Thanks in advance.
shedlight,
Clean a computer monitor by using a monitor wipe that can be purchased at any local electronics store. You can also use a soft cloth and water to clean a montior. I do not recommend using a towel.
Thanks,
Dell-Jesse
Jesse, thanks for answering, I checked in my local market monitor wipes aren't available.
As a alternate you recommended soft cloth, can I use vest (brand name Jockey) old or new whatever you recommend, I can use that because that's the only soft cloth I found.
I'm afraid, I forgot to reply.
Please answer my both the questions, I'd like to know :-
1. As a alternate you recommended soft cloth, can I use vest (brand name Jockey) old or new whatever you recommend, I can use that because that's the only soft cloth I found.
2. What type of soft cloth do you recommend, as you disallow to use towel whereas towel also falls in soft cloth category. Is vest cloth is suitable to clean Dell UltraSharp LED monitor's screen?
Please reply my both the questions.
If you have a microfiber towel, get it slightly damp and wipe off the screen. ZIf you don't have a microfiber towel, you can use a different type of damp soft cloth. It shouldn't be that big of a deal if you just use a shirt or something. As long as you don't get it too wet and the cloth or towel is clean, the monitor will be fine.
