Need suggestions for a mobo!
rbk88
38
Hey everyone,
So I'm building my first ever desktop and I'm looking for a motherboard but am utterly confused at all the terminology and such. I'm on a budget so cheaper is better (hopefully under $100). Please give me your suggestions on the best available motherboard for my specs. I'm looking at the Gigabyte GA-EP45-UD3R but I'm hoping there is a cheaper model. I'm not a HUGE gamer and I'm not going to do anything crazy like dual graphics cards or connect 10 drives either. I just want one that will take advantage of the CPU to the max (maybe easily overclocked) and is reliable/cheap. Thanks a lot!
CPU: Intel E8400 Core 2 Duo 3.0 Ghz.
Graphics : HD Radeon 4830
Connecting one DVD Drive, one internal hard drive.
rbk88
38
Thanks for the suggestions. I just saw on newegg that the ECS mobo received a "great value" award and that's the kind of mobo I'm looking for. However, it seems that in the comments people are saying its nearly impossible to overclock, and that is one important factor for me. Are there any other ideas? Also, since I'm going to buy a 4830 graphics card, it won't matter that the mobo has a good GPU correct? Thanks
sub mesa
That is true, the ECS board doesnt do overclocking. Maybe you can find other boards like GeForce 9300 chipset which is quite good, boards which do support overclocking. I'm not into overclocking really, i prefer under-clocking more than over-clocking. ;-)
rbk88
38
When you are looking for a mobo, what kinds of things should I be looking for? What is the most important aspects for a reliable and fast mobo? Is it the FSB? The DDR2?
sub mesa
The chipset is the most important. Other important things are:
- power consumption (influenced by many things; but the motherboard having Solid Capacitors is also a good sign)
- additional features (firewire, howmany USB/SATA ports, howmany PCI/PCIe ports)
- BIOS options/functionality
Generally, you first choose a processor, then choose a chipset, then choose a motherboard. On Intel most chipsets use alot of power, but newer nVidia chipsets are quite efficient and do not require things like heat pipes or active cooling to operate.
rbk88
38
oh wow I never realized the "chipset" until now. So you would definitely recommend an nVidia chipset? Also, I'm assuming you are talking about the north bridge? Since I already have bought the processor (E8400), now I need to choose a chipset. so this chipset won't affect compatability of anything else right such as the graphics card I'm going to buy? Also, which nvidia chipset would you recommend (the nForce 700)?
sub mesa
Chipsets usually consist of both north bridge and south bridge -- but nvidia chipsets often consist of only one chip serving both as north bridge and south bridge. Simply said the north bridge connects your CPU, memory and Graphics card, while the south bridge connects all the Serial ATA/Ethernet/USB/PCI communication -- the less fast stuff.
The nVidia GeForce 9300/9400 chipset is also known as MCP7A or nForce 730i MCP -- three names for the same product nvidia might not even sure about themselves ;)
rbk88
38
Thanks for all the info guys. The thing I want to know now is what exactly am I LOSING by getting the cheaper mobo in this case?
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX which costs about $115
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
GIGABYTE GA-G31M-ES2L LGA 775 Intel G31 Micro ATX which costs $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357
Can someone explain to me what exactly makes up the price difference? Will I not be able to fully utilize my CPU by getting the cheaper one? What about the difference in "standard RAM" how will that affect anything? Thanks
Crashman
Polypheme
Former Staff
More features and great overclocking for less money: ASRock P45XE
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157143
rbk88
38
Thanks for the suggestions I will definitely consider that product. However, do you know of any other mobo's that are cheaper (maybe around $60-80)? I just want a mobo that is reliable with quality performace/speed. It doesn't need to support Sli, raid, dual graphics, blah blah blah.
