[SOLVED] Need Suggestions for First Build for HS Freshman
MattyZDBA
Commendable
Jun 15, 2020
9
Approximate Purchase Date: early June
Budget Range: $1500 before rebates and shipping
System Usage from Most to Least Important: games (FPS, racing sims), surfing web, movies, school work
Parts to Upgrade: n/a
Do you need to buy OS: Yes, Windows 10
Preferred Website(s) for Parts: newegg.com, amazon.com, bestbuy.com
Parts Preferences: Intel for processor, ASUS or Gigabyte for motherboard, Samsung for NVE/SSD storage, NVidia for GPU
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 2560 x 1440 (assume GIGABYTE G27Q monitor)
Additional Comments: clear/smoked glass panel to see RGB fans (mesh a close second), water cooling OK, but quieter fans a close second, mini tower, def. no desktop cases
And Most Importantly, Why Are You Upgrading: father+son project
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
Intel Core i7-11700F
https://www.newegg.com/intel-core-i7-11700f-core-i7-11th-gen/p/N82E16819118263
GIGABYTE G27Q 27"
https://www.newegg.com/p/N82E16824012015
If you go with an Nvidia card you want a G-Sync monitor in order to get the most out of these newer RTX 30XX series cards. The thing with 1440 resolution is the cost of the gpu + psu and tbh you don't want anything less than an RTX 3070 and that card is almost lowballing it for that resolution hence the reason the monitor in this build is 1080P. The motherboard down below was named best B660 budget board by at least two tech sites. With games as large as they are these days best to go with a 2TB SSD if it fits within the budget. I'm no good with small case builds so hopefully someone post a better case for your needs on this thread. I could have cut the cost on this build but it looks like you want RGB...
https://www.newegg.com/black-fractal-design-focus-g-mini-micro-atx-mid-tower/p/N82E16811352068
Fractal Design Focus G Mini Black Micro Tower Computer Case $55.99
Exhaust fan for that case.
https://www.amazon.com/ARCTIC-F12-PWM-PST-Technology/dp/B08WH3XV6G/
ARCTIC F12 PWM 120mm 4-Pin Case Fan $9.99
https://www.newegg.com/evga-supernova-650-g5-220-g5-0650-x1-650w/p/N82E16817438163
EVGA SuperNOVA 650 G5, 80+ Gold 650W, Modular, Compact 150mm Size, Power Supply $69.99
https://www.newegg.com/p/N82E16813144531
MSI PRO B660M-A DDR4 $129.99
https://www.bestbuy.com/site/intel-...700-desktop-processor/6492588.p?skuId=6492588
Intel Core i5-12400F $159.99
https://www.amazon.com/DEEPCOOL-GAMMAXX-Heatpipes-Motherboard-Control/dp/B08C231WQC/
DeepCool GAMMAXX GTE V2 RGB CPU Cooler $39.99
https://www.newegg.com/corsair-16gb-288-pin-ddr4-sdram/p/N82E16820236768
CORSAIR Vengeance RGB RS DDR4 3200 16GB (2x 8GB) CL16 $74.99
https://www.amazon.com/PNY-CS1030-Internal-Solid-State/dp/B08M446772/
PNY CS1030 2TB M.2 NVMe PCIe Gen3 x4 Internal SSD $164.99
https://www.amazon.com/ASUS-Graphics-DisplayPort-Military-Grade-Certification/dp/B0985YLRB3/
ASUS TUF Gaming NVIDIA GeForce RTX 3060 Ti V2 OC 8GB Graphics Card $549.99
Wíndоws 10 Hоmе USВ | 2022 | Frее Uрgrаdе tо Wíndоws 11 $109.00
https://www.bhphotovideo.com/c/product/1684794-REG/msi_optix_mag2732_27_monitor.html
MSI Optix MAG2732 27" 165Hz G-SYNC IPS Gaming Monitor $199.99
Total: $1490
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-g-mini/black/
https://www.msi.com/Motherboard/PRO-B660M-A-DDR4
https://www.deepcool.com/products/Cooling/cpuaircoolers/Gammaxx-GTE-V2-CPU-Cooler/2021/172.shtml
https://us.msi.com/Monitor/Optix-MAG2732
https://ark.intel.com/content/www/u...2400f-processor-18m-cache-up-to-4-40-ghz.html
Gaming benchmarks for the i5 12400 / 12400F
Overclocking: Maybe
Overclocking is less valuable than it was 5 or 10 years ago, but maybe you are doing it purely as an experiment rather than for sheer performance purposes?
I don't think you'll get much enthusiasm here for SLI/Crossfire.
Do you have an over-riding strong reason to use an 11th generation processor rather than current 12th generation?
Reactions: Why_Me
MattyZDBA
Commendable
Jun 15, 2020
9
St
It's mainly for dollars. When I built my home lab two years ago around a 12-core Ryzen 9 3900, my expense went to ~$2200, so I figure if he's not hosting 5 VMs he may be able to run on an older generation chip to save a few dollars to put into the GPU or monitor. I'm thinking a 4 year lifespan for the build (if he lives on-campus in college, he may want a gaming laptop then).
Noting the other comments so far, if the budget increases to $1750 (+$250) would opt to go with a 12th gen processor or upgrade the other components?
MattyZDBA
Commendable
Jun 15, 2020
9
Total: $1490
Thank you for the detailed build spec. Noting what @Lafong mentioned, if the budget increased to $1750 (+$250) , where would you allocate it best?
Reactions: Why_Me
A 2x16GB set of RAM instead of that 2x8GB set, and an SSD with DRAM cache instead of the PNY SSD I previously posted. Put any leftover money towards MS Office (homework).
https://www.newegg.com/corsair-32gb-288-pin-ddr4-sdram/p/N82E16820236570
CORSAIR Vengeance RGB Pro 32GB DDR4 3200 (2x16GB) CL16 $129.99
https://www.amazon.com/Samsung-970-EVO-Plus-MZ-V7S2T0B/dp/B07MFZXR1B/
SAMSUNG 970 EVO Plus 2TB M.2 NVMe Internal SSD $219.99
MattyZDBA
Commendable
Jun 15, 2020
9
Incorporating your suggestions and getting feedback from my son regarding the case and monitor...
(will bring over existing BlueTooth mouse. went over budget but may be able to shave excess if we buy parts through July 4 sales and maybe lower capacity UPS)
PCPartPicker Part List: https://pcpartpicker.com/list/HVr38r
CPU: Intel Core i9-11900K 3.5 GHz 8-Core Processor ($391.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler ($46.99 @ GameStop)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste ($10.94 @ Newegg)
Motherboard: Gigabyte Z590 AORUS MASTER ATX LGA1200 Motherboard ($199.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($115.99 @ Newegg)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 NVME Solid State Drive ($199.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card ($319.99 @ Newegg)
Case: Fractal Design Meshify 2 Compact TG Light Tint ATX Mid Tower Case ($140.98 @ Newegg)
Power Supply: EVGA SuperNOVA GA 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($79.99 @ Newegg)
Operating System: Microsoft Windows 11 Home OEM 64-bit ($99.98 @ Newegg)
Monitor: Dell S3222DGM 31.5" 2560x1440 165 Hz Monitor
Keyboard: Corsair K57 RGB Bluetooth Wireless Gaming Keyboard ($99.99 @ Newegg)
UPS: APC BX1500M UPS ($200.00 @ Newegg)
Total: $1906.82
Generated by PCPartPicker 2022-06-23 22:34 EDT-0400
Total: $1906.82
No offense, but that's a horrible build. Not only is thar board & cpu old tech, but the 11900K was a crap cpu to begin with. btw that CM 212 won't handle that i9.
Your link says 2186 dollars; not 1906; I guess that is because it includes a monitor?
Not excited about the cooler.
Rarely see a UPS included, but if you insist......
You can get several variants of the 12th gen 12700 for 340 to 400.
Here's your WiFi + Bluetooth 5.2 along with a graphics card that's meant for 1440P.
https://www.newegg.com/black-lian-li-lancool-ii-performance-atx-mid-tower/p/2AM-000Z-00086
LIAN LI LANCOOL II MESH C PERFORMANCE $119.99
https://www.newegg.com/super-flower-leadex-iii-sf-850f14hg-850w/p/1HU-024C-00005
Super Flower Leadex III 850W 80+ Gold Modular Power Supply $109.99
https://www.newegg.com/p/N82E16813145385
GIGABYTE B660M GAMING X AX DDR4 $149.99
https://www.bhphotovideo.com/c/prod...12400f_core_i5_12400f_desktop_processor.html/
Intel Core i5-12400F $169.95
https://www.amazon.com/DeepCool-Performance-Cooler-Dynamic-Bearing/dp/B09PCWK7SP/
DeepCool AK400 CPU Cooler $34.99
https://www.newegg.com/corsair-32gb-288-pin-ddr4-sdram/p/N82E16820236541
CORSAIR Vengeance LPX DDR4 3200 32GB (2x16GB) CL16 $107.99 + $3 off w/ promo code ESBBT2Z346
https://www.amazon.com/PNY-CS2130-Internal-Solid-State/dp/B0869C35V2/
PNY CS2130 2TB M.2 PCIe NVMe Gen3 x4 Internal SSD $174.99
https://www.amazon.com/MSI-RTX-3080-LHR-12G/dp/B09TNLQRSJ/
MSI GeForce RTX 3080 Ventus 3X Plus 12GB OC Graphics Card $799.99
https://www.amazon.com/Microsoft-Windows-11-Home-USB/dp/B09V6R9QZZ?th=1
Microsoft Windows 11 (USB) $139.00
https://www.amazon.com/ASUS-VG27AQ1A-Supports-Compatible-DisplayPort/dp/B08CZ8QJTX/
ASUS TUF Gaming 27" 2K HDR (VG27AQ1A) - QHD (2560 x 1440), IPS, 170Hz, 1ms, Extreme Low Motion Blur, Speaker, G-SYNC Compatible Gaming Monitor $312.99
Total: $2116.87
https://www.asus.com/us/Displays-Desktops/Monitors/TUF-Gaming/TUF-GAMING-VG27AQ1A/
https://www.gigabyte.com/Motherboard/B660M-GAMING-X-AX-DDR4-rev-1x#kf
https://global.deepcool.com/product...AK400-Performance-CPU-Cooler/2021/15222.shtml
Reactions: helper800
What is better for your intended tasks:
Upgrading RAM from 16 to 32?
or for about the same expense:
Upgrading CPU from 12400 to 12600?
I have no idea..............but I'd try to find out. Presumably from those who plays whatever games the freshman plays, to the extent gaming is the most important task.
Likewise......does he need a 500 dollar video card or a 800 dollar video card? What is the marginal advantage of the latter?
Does he anticipate 80% of power on hours will be gaming, and 20% doing much less demanding stuff? Or vice versa?
Have you renounced SLI or overclocking?
$500 gpu is meant for gaming at 1080P and overclocking isn't the thing it used to be. Minimal gains aren't worth the extra cost ... especially on a sub $2200 budget.
Thank you @Lafong. Will revisit tomorrow for another go.
If you want to OC this CPU would do great:
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor ($241.00 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler ($89.90 @ Amazon)
Motherboard: Gigabyte Z690 UD AX DDR4 ATX LGA1700 Motherboard ($189.99 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($139.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive ($114.46 @ Amazon)
Video Card: MSI GeForce RTX 3080 12GB LHR 12 GB GAMING Z TRIO Video Card ($849.99 @ Amazon)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case ($89.99 @ B&H)
Power Supply: EVGA G5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($104.99 @ Amazon)
Monitor: HP X34 34.0" 3440x1440 165 Hz Monitor ($394.99 @ HP)
Total: $2215.30
Generated by PCPartPicker 2022-06-24 00:40 EDT-0400
If you would rather pass on the CPU OC and get more performance:
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor ($312.96 @ Newegg)
CPU Cooler: Scythe Mugen 5 S 51.68 CFM CPU Cooler ($56.99 @ Amazon)
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard ($169.99 @ Amazon)
Total: $2234.35
Generated by PCPartPicker 2022-06-24 00:48 EDT-0400
Total: $2116.87
The i7 version of that build which includes a board and cooler that can handle that cpu.
WiFi 6 + Bluetooth 5.2
https://www.newegg.com/p/N82E16813144522
MSI MAG B660M MORTAR WIFI DDR4 $159.99
https://www.msi.com/Motherboard/MAG-B660M-MORTAR-WIFI-DDR4
https://www.amazon.com/DeepCool-AK620-High-Performance-Dual-Tower-Dissipation/dp/B09CSXS3X4
DeepCool AK620 CPU Cooler $64.99
https://www.tomshardware.com/reviews/deepcool-ak620-review
https://global.deepcool.com/product...-High-Performance-CPU-Cooler/2021/13067.shtml
or ...
https://www.amazon.com/Rev-B-Cooler-LGA1700-LGA1151-Towers/dp/B09NZGH4RD/
Scythe Fuma 2 Rev.B CPU Cooler $65.99
https://hardwarecanucks.com/forum/t...-review-the-best-cpu-cooler-got-cooler.84709/
https://www.scytheus.com/fuma2-rev-b
https://www.amazon.com/Intel-i7-12700F-2-1GHz-6xxChipset-BX8071512700F/
Intel Core i7-12700F $312.96
https://ark.intel.com/content/www/u...2700f-processor-25m-cache-up-to-4-90-ghz.html
i7 12700 / 12700F gaming benchmarks.
