Need suggestions for graphics card
labbu63
66
ok well im making a gaming computer and just wanted some suggestions for a graphic card under 230 btw this how i plan on to make it
CORE
Core 2 Duo E8500
CASE
Sunbeam Transformer Case
MOBO
GigaByte GA-EP45-UD3P Motherboard
RAM
Corsair XMS2 PC6400 800MHz 2GB DDR2 Desktop Memory
HDD
Seagate Barracuda 7200.12 ST3500418AS 500 GB
OPTICAL DRIVE
SAMSUNG Black 22X DVD+R 8X DVD+RW 22X DVD-R 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD
POWER SUPPLY
BurnerOCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC
CPU COOLER
Thermaltake TR2-R1 / AMD Socket AM2/939/754 / Aluminum / 92mm Fan / CPU Cooler
if u have any suggestions tell me also i only need video card so dont forget bout that btw im planning to add 2gb ram more
i was thinking of getting 4 gigs of ddr2 or 3 gigs of ddr3 but ill take everything under consideration i checked on the mobo site and it gave me a list of suppported memory so i was picking from there ok ill add a 6gb instead of 2x2gb
good choice the 4850 is 120 at tigerdirect i have one and plays everything i wanted it to play gonna get a 2nd one and put it in sli, if u got the money go for the 4890
i am not sure if you guys know about the evga precision tool if you have had is there something like that for the Sapphire Vapor-X Radeon HD 4870 Video Card 2GB btw i choose that one cause it was in between both the other cards and its 2 gb so is there a tool like that for this card here
ok im actually making some changes im goin to change my mobo maybe to a nforce or if u guys can recommend one under 175 thats good also the ram do most mobo's suppport ddr3
how much is that 4870 graphic card and u dont really need 2gb, id go with a 4890 1gb that would be my choice , and mobo dont know which one suits you but id go with one that supports ddr3.
