Hello ,
I'm looking to build an entry level gaming PC and I've found 2 components ( GPU & CPU ) and because it's my first time doing it , I need some expert help
The components :
CPU : i3 6100
GPU : Gigabyte GTX 1050 Ti 4GB
I need help for mostly all of the remaining components.I'm looking for 8GB dual channel RAM and 1TB (WD Blue maybe?).For the GPU I've been also doing some research about the GTX 960 and the R9 380 , but as I have read , they should be about the same.The games that I'm looking to play with solid FPS and graphics are CS:GO , Company of Heroes , Far Cry 3 , Gunslinger , GTA 4. Could the GPU and CPU with the other components of your choice handle these games at least at medium setting 1080p ?
Budget 550 - 600$
The thing is that where I live (Bosnia) the prices are just mad and that makes it very hard for finding components.
Thank you.
The components :
CPU : i3 6100
Budget 550 - 600$
Thank you.
