[SOLVED] Need suggestions on buying Mini/ITX PC pre-built
max13
160
7
4,595
Hi everyone,
I'm currently looking for mini or ITX pc for gaming, due to my room space, I need to get a smaller pc.
And I've been thinking of dissemble my current pc and get some new parts to build a new ITX pc.
This is my current setup
I7 10700
ATX-MB
RX 5700 XT 3 fans
Case TD500Mesh Cooler Master
Or a pre-built mini pc like NUC Intel or something.
I really out of field when it comes to a prebuilt system from HP, Lenovo or some other brands.
Do you guys have any suggestion for those prebuilt mini or ITX pc?
Thank a lot!
https://www.newegg.com/p/N82E16811854110
Phanteks Eclipse P200A $69.99
Exhaust fan for that case.
ARCTIC 120mm Case Fan $5.99
https://www.quietpc.com/asus-b560-i-rs
ASUS ROG STRIX B560-I GAMING WIFI
How long is your graphic card? Some cases might be limited in what they could fit.
A laptop on a vertical stand with screen closed could double as a NUC-like desktop, while retaining the mobility.
It's L=279.89 W=114.35 H=49.55
That's what I'm worried..
I don't want to buy a new gpu for now because its overpriced..
Most manufacturers (and all that worth their salt) do list the maximum dimension of components their case could fit, in terms of graphic card length and CPU cooler height.
Just need to keep that in mind, if you do go down that route.
