Need suggestions on GPU for current build.
SASANKGS
Commendable
Jul 6, 2016
Hello everyone. I want to upgrade to a better GPU. These are my PC specs.
Intel Core i5 2400 @ 3.1GHz... NO OC
Intel DH67BL motherboard.
500GB Seagate HDD. 7200rpm.
6GB DDR3 RAM. (Not gaming ram)
Monitor - LG. 1600x900 native resolution. (Note this. I need answers based on this)
Cooler master Thunder 500W power supply. It has extra pins to power GPUs.
And my current GPU is XFX HD 6670. I do not feel bad if you laugh at this 😀DDD
My requirements are.... average of 50fps while recording the gameplay.
And 60fps when playing as it is. No recording.
I do not max out the graphics in any game. All I need is good fps for my recordings.
The games I play include csgo, left 4 dead series, Payday 2, COD BO2.
Planning on buying GTA 5, Rust and left 4 dead 3 (when it launches).
I do not buy crazy intensive games. Just basic ones that rely on my good cpu.
Medium-High settings at 1600x900 is my target.
I am from India and my budget is 8000-10000.
Suggestions in USD will not help me because there is a huge difference in price. US and IND.
Best example is RX 480. Base variant is 200$ in US. While here is costs equivalent of 340$.
So please suggest price in INR. Also give me comments on AMD RX 460. It is supposed to be
good enough for games I play... What is possible price of rx460 in India ?
THANKS IN ADVANCE. AND SORRY FOR SUCH A LENGTHY POST.
The GTX750Ti is available within my budget. But it was released in early 2014. Is it still a solid offering ?
Any idea on how the AMD RX460 fares again the 750ti or 950Ti ?
Does GTX750Ti support shadowplay ?
EDIT :: The 750ti supports shadowplay. According to this site.
http://www.geforce.com/geforce-experience/system-requirements
Yes, it support the shadowplay. If you can get the 950 within your budget, even better.
AMD gpus do not have recording feature and this creates a substantial load on the computer while gaming.
You can wait for it to be released as the pricing of GTX gpus will be affected anyway. So you can get better nvidia gpu for the same money. Also nvidia supposed to release GTX 1050 at some point soon.
