Need suggestions to buy cooling system and big tower case
Vimalfxartist
213
Hi,
I am Vimal. I am an FX Artist
My Pc workstation config is -
Sabertooth 990FX R.2 MotherBoard
8150 Bulldozer Black Edition Processor
FirePro V5900 Graphic Card
4 x 4 Ram 16Gb DDR 3
650 watts Smps
Cooler Master 690 II Ad cabinet.
I need to buy an cooling system for my above cofig.
Please suggest me the best cooling system and it should support the above config and it should suit my cabinet. Else I will buy a new big Tower case. Suggest me a good big Tower case.
I live in chennai (hot city) - Tamilnadu - India.
Corsair has a 5 year warranty on AIO Coolers and will cover the cost of replacing if ever there is leakages found.
http://www.techpowerup.com/reviews/Swiftech/H220-X/9.html this is a review from techpowerup http://www.techpowerup.com/reviews/Swiftech/H220-X/9.html
Cons for going H220
Is all copper construction, not aluminum
- Thermally it beats all air coolers and CLCs on the market
- It's less than 1/4 as loud as the h100i
- It's "open loop, meaning you can add GPU water blocks< MoBo blocks whatever
- It's pump is a high quality pump better than the ones (Revision 4) that come with the custom loop kits costing $200 and up.
- You can monitor fluid level in the reservoir, potentially catching a leak before it does damage.
-It comes with an 8 port PWM fan splitter
-Purchased separately, the parts would go for $230
What does cons mean?
It was a mistype. I meant it was Pros for getting an H220
The things I listed below are the advantages of getting an H220 over a h100i but its more expensive though.
ok.
