Hi,
So with battlefront coming up i want to upgrade my gaming setup. (that's not all i do of course, i'm an IT student so my pc really is a workhorse)
But i have some questions before a spend my hard earned money, i'm sure i'l get some on this awesome forum. i'm buying a few things so i'l split them up.
In the header's are links the the specific product i'm talking about, all links go to amazon.de.
I need an answer to the RAM question the most.
1. Monitor
GPU
RAM
Thanks for your time and patience
1. Monitor
Why:
I have a crappy 60hz TN pannel from medion and i'm quite disapointed about the colors so that's the main upgrade
Question:
Do you reccomend this monitor? I would like GSync, maybe their is a 120hz GSync monitor for the same price out there?
Question:
Why:
I need a new gpu that can push higher frame rate's and since GTA V i want more then 2 Gb VRAM. i chose this one because it seems to be the only one with a backplate.
Question:
Would you recommend this card?
Question:
Why:
I have 8 Gb as of now but RAM seems to be dropping so much and with an extra monitor (3 when i have the new one).
Question:
I have the same RAM but a 2*4 kit. Can i combine the 16Gb kit and the 8Gb kit for a grand total of 24Gb RAM? (my mobo: gigabyte z87x-d3h)
If that doesn't work, Can i send back the RAM to amazon? i know it's on the site but i don't speak german, i just buy it from there because it's cheaper (i'm from belgium)
Question:
