Need to buy 2560x1440 card for 1440P Monitor
Tom92602
145
I am about to buy a 2560x1440 monitor so I need to get a new video card.
My Dell only takes half-height cards and I don't game. (Well, maybe some MAME games)
I am looking for the sharpest picture with the most dazzling colors.
I am looking at the Radeon 6450 and Nvidia 630 cards:
Nvidia 630 choices:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500304
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121778
Radeon 6450 choices:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127738
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121439
Which should I pick?
Thanks..
If you can $100, get this half height amd 7770. Better performance than both of those cards and it should still fit the pc.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131477
If that doesn't work out I recommend getting a 7750 from AMD.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150612
http://www.newegg.com/Product/Product.aspx?Item=N82E16814129274
If you would like to stay around that price than the GT 630 seems to be the way to go.
http://gpuboss.com/gpus/Radeon-HD-6450-vs-GeForce-GT-630
