I want to use my Apple Time Capsule, but it can only connect via Ethernet WAN. From what I read, I will need a Verizon router to connect the Fiber Optic WAN via the Coax Cable, and then connect the WAN Ethernet on my Apple Time Capsule to a LAN Ethernet port on the Verizon router. Then I would need to set the Verizon router to bridge mode to prevent a double NAT.
First, is the above scenario correct so I can use my Apple router?
Second, what is the cheapest Verizon router that will serve this purpose of simply converting Fiber optic Coax WAN --> Ethernet LAN? Can I use a Verizon Westell 9100EM or an Action Rev I?
Thank you
Thank you
