Need to cut and join 15 pin coumpter cable
ramuo
hello i am new here. some help is much appreciated. i cut the 15 pin computer cable and notice there was three course and the rest finer wire altogether not 15 wire, and resolder all of them color matching. i had to cut the end off to pass the cable through a tube under concrete floor the head too big. after I resolder all wire and tried it, i get no signal via computer to enternal monitor. help any suggestion. pls.
hello tks for responding to my querry. yes there are other options hdmi rca. I use the pc option on the tv monitor. I already cut head off and run wire under concrete tube. most computer older do not have hdmi,
A VGA cable carries an analog signal,
and the maximum length decreases as the resolution goes up.
so,
1024x768 can run effectively over a 9 meter (30 ft) cable, but
1600x1200@60Hz won't work well past 1 meter (3.5 ft).
Your options are to user repeaters to increase the distance
to over 600 ft - http://www.networktechinc.com/cat5-vga.h…
or use DVI instead. Since it's digital it can carry longer, even with high resolutions, up to 30 ft
- http://www.datapro.net/techinfo/dvi_info…
Hope that helps...
