I went through the forum and haven't found info to help me.
I hope maybe with some details provided you can.
I'm not a gamer, although my system is built based on components made available because of the gaming community (for which I thank them).
I use mostly Photoshop and Premiere Pro (Adobe Creative Cloud).
I move files from my network storage to my workstation,
work the files on my RAID0 drives and then move the new files back to the network.
I currently use only one of 2 LAN ports on my workstation because I haven't figured out how to configure them to recognize and utilize both in tandem to improve transfer speeds on the LAN.
When I attempt to create a Bridge with 2 5e cables running to the switch I get the following message:
"To create a Network Bridge, you must select at least two LAN or High-Speed Internet connections that are not being used by Internet Connection Sharing" ???
I would like to move large files to and from the network faster if possible.
I will typically drag a whole folder of files to my local drive (mix of large and small files).
Currently files transfer as low as 5MB/s but sometimes as fast as 25MB/s from the network.
My goal is closer to 100MB/s.
What can I do to achieve this?
______________
> Do you have guidance on configuring dual LAN ports on this system?
> Are there settings on my Router or other components that will make a significant difference (Jumbo frame - higher is better, right?)
> Would CAT6 cables make any difference over CAT5e?
> Do I have a weak link in this setup that is causing a bottleneck that I can build around?
> I read on one of the Forum Stickys (Ultimate Modem/Route Setup Thread) that using one than one router is an option (and potentially a config nightmare) is this an viable option for my goals?
> Will Drobo 5N NAS with mSATSA SSD based cache vastly improve transfer rates over my current FS models?
> Maybe I'm just spoiled by the transfer rates from my USB3.0 devices and moving files from drive to drive within my workstation (almost always in excess of 100MB/s)? Is this not a reasonable goal on a gigabit network?
______________
My current setup;
> 2 - Drobo FS units each with 5 drives - 7200RPM 6Gb/s
one with 4TB drives, the other with 2TB drives (30TB total)
setup as RAID5 for each with 14.5 & 7.2 usable space (21.7TB)
(I plan to add a new Drobo5N with 4TB drives down the road)
I prefer Drobo because of the 4 brands of NAS I've used over the years this is the most dependable to avoid data loss.
> CAT5e cables to switch;
> Trendnet Gigabit Switch TEG-S24Tg (14 of 24ports being used)
> Router - DLink DIR-655
> Workstation x79 based Custom built;
>> ASRock x79 Extreme9 Motherboard w/Corsair 850w Gold PSU
>> i7-3820K CPU watercooled (Corsair H100) OC 4100MHz stable
>> 32GB RAM 8 - 4GB Mushkin Black DDR3 1600
>> Corsair Force3 240GB SSD used as OS drive
>> 2 - Seagate Hybrid 750GB ST750LX RAID0 used primarily as scratch drive
>> 2 - Samsung 500GB HD501LJ RAID0 used primarily to hold project files
>> Dual Braodcom Netlink Gigabit Ethernet Adapters (on board)
> Windows 7 x64
> Also on this system is a Blu-ray burner (HL-DT-ST)
>> Geforce GTX460v2 (1GB GDDR5) - soon to be upgraded to GTX670, 770, or 680 4GB
>> Dual Dell U2410 monitors
>> Epson Photo R200 printer
>> various USB3.0/USB2.0 External drives, keyboard, trackball
>> IEEE1394 based film scanner
> Network includes;
>> ATT Uverse DSL Gateway
>> Verizon Wireless Network Extender
>> DirecTV Genie DVR
>> Dell Windows7 x64 workstation
>> Lenovo W520 laptop on LAN dock or WiFi
>> 2 - Brother Laser Printers
>> HP Z3100 44" Plotter
Thank you for your insight and suggestions
______________
______________
My current setup;
> Windows 7 x64
> Network includes;
>> DirecTV Genie DVR
