Need to Finish loop need help with parts.
  • Thread starter Deleted member 362816
  • Start date
D
Guest
Prefer EK since I already have half the parts.
Here is what I have.
EK-Supremacy MX CPU water block
EK-Coolstream PE 360mm performance radiator
EK-XRES 100 DDC MX 3.1 PWM reservoir/pump combo
3 EK-Vardar F3-120 (1850rpm) fans
EK-Tube ZMT Matte Black tubing
Here is what I need. Need to know the rest of the parts.
2 EVGA 6173 GTX 1070's
6800k
Need to add a 25-30mm top rad 360mm
2 gtx 1070 waterblock's with backplates
One of those Card bridge's--- Never used these before I am using a EVGA HB SLI Bridge. 1 Slot space.
EK told me that the current kit that I have will work with adding parts to. They said the Pump/Res I have should be up to the task. If it is not please let me know and I will make 2 Separate Loops.
D
Guest
Does this look right.
Product Name Unit Price Qty Subtotal
Continue ShoppingUpdate Shopping Cart
EK-ACF Fitting 10/16mm - Nickel
$ 6.49
$ 19.47 Remove item
EK-CoolStream SE 360 (Slim Triple)
$ 59.99
$ 59.99 Remove item
EK-FC1070 GTX - Acetal+Nickel
$ 125.49
$ 250.98 Remove item
EK-FC1070 GTX Backplate - Black
$ 34.99
$ 69.98 Remove item
EK-Tube ZMT Matte Black 15,9/9,5mm
$ 5.49
$ 16.47 Remove item
EK-FC Terminal DUAL Serial
$ 20.49
$ 20.49 Remove item
