I have an old ATI Rage 4 (AGP) card with one of the small fans glued directly to the GPU. Well, the fan popped off the chip the other day, and now I'd like to re-glue it back on. Does anyone have a suggestion on what to use. Would regular Wal*Mart 5-min epoxy be adequate, or should I look at maybe getting a "sample" of some potting compound type epoxy (the gray stuff) sent to me. Any other suggestions would be appreciated.
BTW: There are no mounting holes for any other physical attachment of the fan.
Thanks
Thanks
