Okay guys , i am going to need someone to help me with the identification of the PC case i have , i will drop picture here on imgur sharing page, hope anyone finds it familiar
The thing is that, I bought a gtx 1080 ti and it wont fit in it , and was going to change it , and trying to sell old one
If you're accepting recommendations I offer Vivo's Titan m-ATX case. But will a 1080 Ti fit in there? https://vivo-us.com/products/case-v05 says -VGA card length up to 410mm. That's plenty for any1080 Ti. Personally I have the EVGA 1080 Ti FTW3 Hybrid in that case. It has 2 places for fans(120mm or 140mm) or a 240mm radiator at the top of the case. It comes with 2 120mm fans up front and a 120mm on the rear of the case. Do you have a beast of a cooler? The Noctua NH15 or the Be Quiet Dark Rock Pro3 will both fit. I have the 160mm 212 Evo installed with an extra fan...
If you're accepting recommendations I offer Vivo's Titan m-ATX case. But will a 1080 Ti fit in there? https://vivo-us.com/products/case-v05 says -VGA card length up to 410mm. That's plenty for any1080 Ti. Personally I have the EVGA 1080 Ti FTW3 Hybrid in that case. It has 2 places for fans(120mm or 140mm) or a 240mm radiator at the top of the case. It comes with 2 120mm fans up front and a 120mm on the rear of the case. Do you have a beast of a cooler? The Noctua NH15 or the Be Quiet Dark Rock Pro3 will both fit. I have the 160mm 212 Evo installed with an extra fan. https://www.newegg.com/Product/Product.aspx?Item=2AM-003M-00005
