[SOLVED] ? need to know about YMDK Wings Kit & build advice
DREDKNOT_2077
142
with this YMDK Wings Kit do i need to do any Soldering im i reading it this right
https://ymdkey.com/products/ymdk-wi...de-navy-cream-switches?variant=39301297864765
or this one
https://ymdkey.com/products/gbymdk-...hotswap-v1-pcb-diy-kit?variant=39348940832829
if i am can i still open it up to add some vibration dampening pads
an if i go with the keycaps off this board
https://www.amazon.com/gp/product/B07MGGGMPV/ref=ox_sc_saved_title_6?psc=1
an use them on the ymdk wings would i still get the space gap between the keys this is important to me
my planned build is the ymdk with plus the keycaps off the 2088-Black
with a full set of KAILH BOX DARK YELLOW SWITCHES an GLORIOUS O-RING SWITCH DAMPENERS 40a soft
either thin or thick not sure which would be best
an to top off build was going to give a custom paint job by adding a spray painted white pattern not sue what id go with yet.
any advice on initial ask an any on planed paint scheme will be welcomed
note i like a heavier trigger
an my reason for wanting the low profile caps off that
board
is iv got on my current pc build a drop swift with
kailh heavy box ancient greys an on the num pad the box dark yellows
with these caps - Retro Steampunk Keycaps Set
https://www.amazon.com/gp/aw/d/B089763442?psc=1
i like the gap spacing an the round shape but for ymdk id like square ones
but cant find a good stand alone set other then the one on the mentioned
2088-Black an i was just trying to confirm the 2088-Black caps on the
ymdk wings board would still have the gap spacing ?
That kit will come with switches soldered on, you will however need to provide a keycap set for the build and you won't have LED's on it, just the switches. If you want a hotswap option, look at this;
https://ymdkey.com/products/gbymdk-wings-aluminum-cnc-top-bottom-qmk-rgb-hotswap-v1-pcb-diy-kit
The soldered version and the hotswap versions will allow you to remove the frame(both top and bottom) after undoing some screws so you can do your artwork on the frame itself though I'd prefer the hotswap kit so you can work with switches of your choosing, on the fly as opposed to dealing with a permanently soldered on option, which often times is a pain to desolder and resolder.
Reactions: DREDKNOT_2077
