hello there I'm not sure if I'm worrying to much but I have a Gigabyte GA-z270x Gaming 8 motherboard on which has 2 rgb headers. Gigabyte states that max load is 2Amps and can control 2m worth of led strips. Firstly from what I can tell the max 2Amps is for both headers together but does this mean that each header can only take 1Amp each. For example I have PHANTEKS PH-LEDKT_CMBO RGB LED Strips Starter/Combo Set which includes 2 x 400m led strips at 0.42Amps each and I have just purchased 4 x Akasa Vegas X7, 120mm 12cm RGB case fan which run at 0.29Amps. Altogether this works out at 2Amps exactly but as I'm using a rgb splitter to connect them all so everything is in sync using gigabytes rgb fusion. One rgb header would be using 1.13Amps and the other 0.87Amps. So I guess my question is will this be okay as I'm not exceeding the 2Amps max or is each header only limited to 1Amp each.
I hope that I've explained myself clearly enough and any help would be greatly appreciated.
