Need to know if this will work and fit together
YouJustGotCrafted
35
hello guys building my new PC would like your input on if all these parts will work together and will fit into the case without a problem. (if there are parts that are better for the money or if this wont work in the case or in general it wont work please send that in the reply with the part that i need. Here are the specs. thanks guys
CPU
Intel Core i7-3770K 3.5GHz Quad-Core
$314.99
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing
$29.99
Motherboard
ASRock Z77 Extreme6 ATX LGA1155
Combo or $144.99
Memory
Samsung 8GB (2 x 4GB) DDR3-1600
$34.99
Storage
Seagate Barracuda 2TB 3.5" 7200RPM
$95.98
Video Card
EVGA GeForce GTX 660 2GB
$209.99
Sound Card
Creative Labs Audigy SE
$25.99
Case
MSI IN-623 (Black) ATX Mid Tower
$54.99
Power Supply
Cooler Master 650W ATX12V
$69.49
Optical Drive
Samsung SH-224BB/RSBS DVD/CD Writer
$19.99
Operating System
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Combo or $99.99
You don't need that sound card. It's a mid-range sound card and your motherboard will have equal or better audio. The only improvement to make for sound would be spending $75-$150 on a sound card which I deem unnecessary.
Which model of Coolermaster power supply is that? The only good 650w they make is the Silent Pro, if its not a Silent Pro then do not buy. Unless you're handy with a fire extinguisher. Your build would get by fine on 500w. Get something like this...
SeaSonic S12II 520 Bronze 520W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
THAT is a power supply.
I would but it won't be that fast, for the same price get an i5 3570k and an ssd, or upgrade the gpu to a gtx 670 or radeon hd 7950
If you are planning on playing with high anti-aliasing, I would get the 7870 instead, if you are looking to overclock get a 7950.
Hmmm, I see 7870 winning 80% of the titles. And on the ones where the 660 wins AA is not used or really low settings. Unless in your original post you meant to type 660ti. Which yes the 660ti is generally better but its also the same price as the 7950 which is better. Also AMD cards overclock better than 660 series cards.
http://www.anandtech.com/bench/Product/548?vs=660
You do not need 650w. The 660 does not use very much power, neither does your CPU. I run a system similar to yours with a 7870, 5 hard drives, a half dozen fans, and 2 light strips and I pull 375w from the wall at full load. 500w is more than enough.
You will max out WoW easily. Crysis 3 you can maybe play on high settings. It's hard to tell when it hasnt been released yet. I played the BETA on a FX-8320 and a GTX560ti and I had to play on medium. The BETA isn't optimized yet but looking at the projected recommened specs for Crysis 3 you should be alright.
do you want my specs that ive been working with and you can tell from that what to be fixed with? well the budget is 1,100 and here are the specs
CPU
Intel Core i7-3770K 3.5GHz Quad-Core Processor
$314.99
FREE
$314.99
Amazon
Remove
Buy
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
$29.99
$29.99
NCIX US
Remove
Buy
Motherboard
ASRock Z77 Extreme6 ATX LGA1155 Motherboard
$144.99
FREE
$144.99
Newegg
Remove
Buy Combo
Combo discount automatically applied. (View details.)
Memory
Samsung 8GB (2 x 4GB) DDR3-1600 Memory
$34.99
FREE
$34.99
Newegg
Remove
Buy
Add More Memory
Storage
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
$95.98
$95.98
Outlet PC
Remove
Buy
Add Additional Storage
Video Card
EVGA GeForce GTX 660 2GB Video Card
$229.99
-$20.00
FREE
$209.99
Newegg
Remove
Buy
$20.00 mail-in rebate
Add Another Video Card For 2-Way SLI
Sound Card
Choose a Sound Card
Case
MSI IN-623 (Black) ATX Mid Tower Case
$79.99
-$25.00
$54.99
Microcenter
Remove
Buy
$25.00 mail-in rebate
Power Supply
SeaSonic S12II 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
$67.99
$9.65
$77.64
Newegg
Remove
Buy
Optical Drive
$19.99
FREE
$19.99
Newegg
Remove
Bu
Operating System
Well that still only leaves you with $250 for GPU so your options are 7870 or GTX660...
This uses a 7950 but goes $35 over budget.
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($314.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: ASRock Z77 Extreme6 ATX LGA1155 Motherboard ($144.99 @ Newegg)
Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($95.98 @ Outlet PC)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($279.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.49 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($77.64 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.89 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($99.99 @ Newegg)
Total: $1135.94
(Generated by PCPartPicker 2012-12-04 20:10 EST-0500)
well i will also be going to Micro Center on Friday and will be buying combo which im pretty sure is the motherboard and GPU you get $75 dollars off am i right so will this new build that you gave me with the 7950 will it be able to run all games on high mixed with ultra?
Yeah the 7950 is top notch. Really high overclock potential too.
Okay but the case will not work because it doesn't have a spot for the front panel 3.0 usb so any suggestions on a case you can spend a little more because you can deduct $75 dollars from the bill because if you go to the micro center and buy the motherboard and gpu you $75 dollars off which some of that can be put to a better case that has front panel 3.0 usb
Well this one has USB 3.0 front panel and isn't very expensive. I actually am using one right now for my latest build.
Rosewill BLACKHAWK Gaming ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
This one is great too:
Corsair Carbide Series 300R
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
Same one only with a windowed side panel.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139016
These are nice too, come in a variety of colors and with without windows
Fractal Design Define R4 with Window Titanium Grey
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352023
There's a ton of cases that fit your $50-$125 case budget with front panel USB 3.0. Cases are really a matter of personal taste.
for a case, consider the antec three hundred two(similar features as haf 912 but also has front panel usb 3.0 ports).
And OP, if you want to post a potential build from pcpartpicker.com, click the bbcode markup button at the top after you are finished building. A window will pop up. cut and past the info from that window into the text box on this forum. when you hit preview, you will get a nice condensed post with working links that doesn't take forever and a day to scroll up and down through.
