NEED TO Know the Truth (Power Supply)
JFaTaL
Commendable
Feb 29, 2016
52
I Recently bought a Cyberpower PC I know there not know for the best custom REP Buth there computers are good. SO With my buy i got a Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready and my computer has all ready shipped and i seen some ppl saying how this one can fry and ruin my system. IS This a big possibility if so whats my best option. My skill levers with computers isnt the best but i can take apart a computer to clean
side note-but i never taken off cpu fan just incase you need to know
Thank you for checking this out :)
sorry but this isn't useull, but yeah if it turns out to be a bad psu like the corsair cx under high load gaming it can cause some serious damage to your components, or the psu blows up what happened to someone today.
furthermore building a pc is not that hard , we had people that couldn't build ikea furniture that managed to do it.
it took them a long time yes 15 hours but they did it.
You get way more bang for your buck .
Whats a good power supply that you recommend that wont "Blow Up" and can handle gaming and streaming
I Know already it has to be over 600 watts
Can you please check my specs to make sure it can handle it Thanks and is power supply fairly easy to take out and put a new one in?
BLUETOOTH: None
BLKFRISALE1: CM Storm Devastator - LED Gaming Keyboard/Mouse Combo [+0] (Black Color w/ Blue Light)
CS_FAN: Maximum Airflow with 140mm Thermaltake Riing 14 Series High Static Pressure 140mm Case/Radiator Fan [+49] (Blue Color LED)
CPU: Intel® Core™ i7-4790K 4.0 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified) [+54]
COOLANT: None
CD2: None
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CC: None
CASUPGRADE: RGB Multi-Color 16 color LED 2x interior light strips (top, bottom) w/ Remote Controller
CAS: CyberPowerPC X-Titan 100 MID-Tower Gaming Case w/ Side-Window Panel [-31] (White Color)
CABLE: None
DOCKINGSTATION: None
ENGRAVING: None
FREEBIE_VC1: FREE! NVIDIA Rise of the Tomb Raider Game Coupon [+0]
FREEBIE_HD: None
FREEBIE_CU: FREE $50 Amex Gift Card for all Intel Core I7 and Intel Core I5 Desktops and Laptops Purchase
FLASHMEDIA: None
FAN: ENERMAX ETS-T40F-W CPU Cooler w/ Dual ENERMAX Cluster PWM fans [+13]
FA_HDD: None
HS_HANGER: None
HEADSET: None
HDD2: None
HDD: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
HD_M2SATA: None
HD_M2PCIE: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: None
MOUSE: None
MOTHERBOARD: ASUS Z97-K ATX w/ Intel GbLAN, 2 PCIe x16, 2 PCIe x1, 2 PCI, 1 x M.2, 6x SATA 6Gb/s [+16]
MOPAD: None
MONITOR: None
MEMORY: 16GB (8GBx2) DDR3/2133MHz Dual Channel Memory (ADATA XPG V3)
NFC: None
NETWORK: Onboard Gigabit LAN Network
OVERCLOCK: Pro OC (Performance Overclock 10% or more) [+19]
OS: None - FORMAT HARD DRIVE ONLY
PRO_WIRING: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
POWERSUPPLY: 800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready [+8]
RUSH: Standard Process Time: Ship within 7 to 12 Business Day
SPEAKERS: None
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SLI_BRIDGE: None
SERVICE: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SECURITY: None
TVRC: None
TUNING: None
TEMP: None
USBX: None
USBHD: None
VIDEO: EVGA FTW Edition ACX 2.0 NVIDIA GeForce GTX 970 ACX 2.0 4GB GDDR5 PCIe 3.0 x16 [+188] (Single Card)
WTV: None
WNC: None
Since this is a "store" bought model opening it may void the warranty. I wouldn't worry about a problem with your power supply until you actually have a problem with your power supply. Just use the system as is and if an issue develops then you have to address it with the manufacturer while it is under warranty. Once out of warranty you can put another brand power supply in the computer if you need or want to.
That is true thanks for reminding me! anyway you can share your thought or experience of this occurring with these power supply's?
I'm sorry the last PC I bought from a reseller was a 286 back in the 80s, I build all my own and my families PCs from scratch with good quality parts I know and trust. I also tend to use the same base parts for all the family PCs I build so if there is an issue I know what is in the PC.
From the description of parts you listed I don't see a brand or model number listed for the PS so I'm not sure what you are getting.
The PSU that you've linked to, has a maximum of 56x12watts on the 12v rails that's 672 watts. Good PSUs always have nearly all of their power available as 12v power, so that should be much closer to 800w. So at first glance that PSU is not likely to be great, will it do for a single 970 plus other bits, yes, but don't sli on it. For reference a 970 plus system will probably Max out at 400w from the wall, so it'll be OK.
SO IT WONT BLOW UP? LOL
With that level of load I'd be fairly happy, but you'll need to keep the PSU cool enough, they won't be stupid enough to put something in that will fail 'as configured' hence the oversized nature of it. But the moment you put more load on it, it will be at greater risk of going, and they'll simply claim that you modified it, and it's not their problem.
It will need updating before you touch anything else though.
To others reading this, the only reason I am comfortable is that the PSU would have to be incapable providing even 50% of it's rated power to get close to failing, and it can't be that bad, else the company wouldn't risk installing it, the warranty issues alone would shut them down. It's rated for 672W, 350W would be a reasonable power output (not input) required for that system, so about 400W input. So there's enough overhead even if it is incapable of it's ratings. If it were only rated for 500, and in the same situation i'd say don't touch it.
Yeah because if i change the PSU It voids the warranty so im going with keeping it in
