Need to know what pin connectors I need.
Jeremy_8
5
I just purchased a graphics card. I need a different Power Supply because my current one only has 240 Watts. I am looking at getting one with at least 600 Watts. However I don't see what pin connectors my power supply would need for this graphics card. It does not say in the description. If anyone can shed any light I would really appreciate it. Here is the link to the graphics card. http://www.newegg.com/Product/Product.aspx?Item=N82E16814125452 It is a low profile card. Thank you!
It will get it's power from your pcie slot it's connected to. No need to worry about power cables. Not sure what the rest of your system is, but it's not a very demanding card. You really won't need a 600w, a decent 450w to 500w should suffice.
