G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hi,
I need the ability to set the maximum volume that a PC can be set too. The
kids just can't voluntarily keep the volumes reasonable.
The only solutions I have found are a $15 program called NoiseNak, and
Volume.exe, sample code at the microsoft site that I imagine I can tweak and
put it in a loop to force the volume back to some predefined value once per
second.
My minimum requirement is that the volume be set to a predetermined level
and that the setting not be easily changed by a user. The PCs have a volume
control on the speakers and the users can use that if they want a lower
volume.
Thanks
Hi,
second.
volume.
Thanks
