Need to plug water pump to dual socket motherboard, help please!
mateofive
14
Hello!
I need to plug my water pump (one 4pin pwm female cable) to my motherboard cpus, as it is a dual socket motherboard I need 2 4pin conectors, one for each cpu, but I only have one one water pump that will be cooling both cpus.
I can't find any Y adapter for my use 🙁 any ideas please???? thanks a zillion!
Thanks for quick reply, I'm using 2 CPUs, each require 1 4pin pwm connection, and yes that's the problem I only have one 4pin pwm cable (from the watter pump)
Thank you!!!! simple clever solution, the kind that makes you feel like why it didn't occurred to me in the first place!
Again, thank you for taking your time to help me out!
Best regards,
M
