G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
I have a CTX VL series 17 inch monitor. There were periods in which
the video would turn yellowish. If I jiggled the cable just right, it
would fix it...short in the cable.
Well now, I can no longer fix it. The cable needs replacing. I took
the monitor apart and took the cable out. This isn't something I
could just buy off the shelf it appears. Does anyone have any
suggestions on where I may purchase another cable?
Here are the markings on the cable:
E118077 AWM STYLE 2919 LOW VOLTAGE COMPUTER CABLE 80 DEGREES C 30V
VW-1 JI-HAW
I know these specs are probably just for the cable itself an not
necessarily for the entire cable structure. Anyway, abviously one end
has a standard monitor connection and the other end has a wide 11 pin
connector (male) that fits into a female connector on the monitor
itself.
I'll probably try calling CTX later this week (they are closed this
weekend) but I am sure they would charge me an arm and a leg.
Any suggestions welcome.
VW-1 JI-HAW
itself.
