Need to upgrade 2013 home built pc made using tech support forum reccomended build
execpro22
12
Approximate Purchase Date: within the next month or two
Budget Range: under $1,000
System Usage from Most to Least Important: Gaming, watching movies....
Are you buying a monitor: Yes
Parts to Upgrade: whatever will make it run on high settings in games
Do you need to buy OS: No
Preferred Website(s) for Parts: new egg
Parts Preferences:intel
Overclocking: no
SLI or Crossfire: no
Your Monitor Resolution: currently have a 1600x900 monitor. want to upgrade
Additional Comments: (e.g.: Need to have a window and lots of bling, I would like a quiet PC. Please also list specific software or games you're using)
And Most Importantly, Why Are You Upgrading:
Well It finally Happened. I go to boot up Arkham Knight and my PC could not handle it. I have built this PC using your guys recommended build in 2013. This PC has run great for the past 3 years, but it definitely needs an upgrade.
I was hoping to be able to just upgrade instead of buying a whole new rig this time. I would like the PC to be able to handle gaming at high settings and last another three years. Please give me some parts recommendations to upgrade my rig. My budget hopefully is under $1,000. Thanks for the help
Here is my current rig:
$139.98
Tracking #:
61299998790622310392
Write Review
1 x LG Electronics 14x SATA Blu-ray Internal Rewriter without Software, Black Model WH14NS40 - OEM
Write Review
1 x Seagate 1TB Expansion Portable External Hard Drive USB 3.0 Model STBX1000101 Black
6/28/2013
Inv #102811799
Shipped
Ineligible for return
Order #164166096
$834.90
Tracking #:
1ZX799470301671856
Write Review
1 x GIGABYTE GA-Z77X-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Write Review
1 x XFX TS Series P1550SXXB9 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS Bronze Certified Active ...
Write Review
1 x EVGA GeForce GTX 650 Ti DirectX 12 (feature level 11_0) 01G-P4-3650-KR 1GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP ...
Write Review
1 x Intel Core i5-3570 Ivy Bridge Quad-Core 3.4GHz (3.8GHz Turbo Boost) LGA 1155 77W BX80637i53570 Desktop Processor ...
Write Review
1 x ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Write Review
1 x NVIDIA $75 value in-game coin coupon
Write Review
1 x Seagate Desktop HDD ST500DM002 500GB 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Write Review
1 x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Write Review
1 x Microsoft Windows 7 Home Premium SP1 64-bit - OEM
6/28/2013
Inv #102814563
Shipped
Order #164166116
$84.98
Tracking #:
366226072189631
Write Review
1 x Antec Three Hundred Two Black Steel ATX Mid Tower Computer Case with Upgraded 2 x USB 3.0
