C carson.davis Sep 16, 2018 2 0 10 Sep 16, 2018 #1 After buying a WMR Headset, I learned that now you need a CPU with AVX. What's the cheapest upgrade from a Pentium G4560?
Solution richiestang_78 Sep 16, 2018 You can go with an 6th or 7th gen intel Id say get a i5 6500 or i5 7500. If you can afford it then obviously a i7 would be better.
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Sep 16, 2018 #2 Please let us know which motherboard you have. Thanks. Upvote 0 Downvote
C carson.davis Sep 16, 2018 2 0 10 Sep 16, 2018 #3 popatim : Please let us know which motherboard you have. Thanks. MSI B250M BAZOOKA motherboard Upvote 0 Downvote
richiestang_78 Glorious Mar 3, 2015 5,965 687 46,890 Sep 16, 2018 Solution #4 You can go with an 6th or 7th gen intel Id say get a i5 6500 or i5 7500. If you can afford it then obviously a i7 would be better. Upvote 0 Downvote Solution
