Need to upgrade graphics card.need help!
thebunghole69
Hi everyone, I'm just new here.
I'm planning to buy 2G GTX Ti Gigabyte or higher.
my desktop spec:
Intel® Core™ i5-4430S (4C, 2.70 GHz) Processor
8GB DDR3 RAM
1TB SATA HDD
NVIDIA® GeForce® GT 620
this is my pc looks like
https://www.asus.com/us/Tower-PCs/M51AC
I will also buy a new psu to support that graphics card.
Can I upgrade my graphics card with this spec?and can I get a higher one?
Any suggestions.
Thanks guys.
Thanks but I live here in Australia and I checked the price, it costs $350+. Most products that are sold here are expensive.
I am checking this site to buy products.http://.
can you suggest any on that list?.if its ok for you.
Well, I mean all the 950s are really close speed wise, they just have different cooling that might be noisier/not as good for OC etc. I just pick that one because it's price(US)/what you get is the good. If there is a cheaper one go for it. Post what it is and I'll look it over.
I found a cheap one!link. So my system can work with this card?.tnx btw
