[SOLVED] Need to upgrade NVIDIA® GeForce® GTX 750Ti with 2GB GDDR5 Graphics Memory to VR
Oct 11, 2019
7
Hello all,
I have a dell XPS Desktop 8910
IPSKL-VM Motherboard
Processor
6th Generation Intel® Core™ i7-6700 Processor (8M Cache, up to 4.0 GHz)
Operating System
Windows 10 Home (64Bit)
Memory
16GB (1x16GB) DDR4 2133MHz SDRAM
Hard Drive
2TB 7200 rpm Hard Drive + 32GB M.2 SSD
Video Card
Base
XPS Desktop 8910 Base
FGA Module
VMAX1705_135_R/GB/BTS
XPS 8910 Black EPS Chassis
XPS 8910, EPA Chassis (460W)
i would like to upgrade my graphics card to be VR compatible.
what card would you recommend please.
Aug 9, 2019
91
6
35
Hello! Whats your budget for the graphics card? I personally would go for AMD rx 580 8gb for vr. rx 570 is also vr ready but rx 580 would be better. If you like Nvidia then go for GTX 1060
Oct 11, 2019
7
Thankyou for your reply
I don’t know yet my budget, need to look,
Would you have link to these cards please.
This is what dell use to recommend :
PNY Geforce GTX 1070 8GB Graphics Card PCI-e
Must be dated now
Also as a newbie, is all my boards and fans compatible.
Thankyou
7
Brilliant , Thankyou so much, will have a look
GTX 1060 sold out
Also rx 580 is about £160-&170 on eBay ? Are they the same ones or am I missing something?
Wolfshadw
Not enough information in those links to tell if the power supply has the necessary power cables. Look for either a 6-pin (2x3) power cable available from your power supply or a 6+2-pin (2x3 + 2x1) power cable. If you're not finding them, then you're going to need to replace it.
From what I'm finding online, you can just swap out the power supply with a standard one but you may need extra cables for the slim-line DVD drive
https://www.dell.com/community/Desktops-General-Read-Only/Dell-8910-Upgrades-with-photos-for-those-looking-to-get-this/td-p/5103449
-Wolf sends
Oct 11, 2019
7
Yes, after a good look at the sockets, I realised which way round.
Thankyou for your help guys, you have all been brilliant👍🏻👍🏻👍🏻
