need ur expertised advise and help on Overclocking my pc
abidullah
18
hello there frnds.
my name is affy and i need ur expertised advise and help on Overclocking my pc
let me explain my pc details , so that u people can guide me exactly.
Processor(s)
Number of processors 1
Number of cores 4 per processor
Number of threads 4 per processor
Name Intel Core 2 Quad Q6600
Code Name Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Package Socket 775 LGA
Family/Model/Stepping 6.F.B
Extended Family/Model 6.F
Core Stepping G0
Technology 65 nm
Core Speed 1600.1 MHz
Multiplier x Bus speed 6.0 x 266.7 MHz
Rated Bus speed 1066.8 MHz
Stock frequency 2400 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache (per processor) 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel X38 rev. 01
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 6144 MBytes
Memory Frequency 400.0 MHz (2:3)
CAS# Latency (tCL) 5.0 clocks
RAS# to CAS# (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 18 clocks
Command Rate (CR) 2T
System
System Manufacturer Gigabyte Technology Co., Ltd.
System Name EX38-DS4
System S/N
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model EX38-DS4
BIOS Vendor Award Software International, Inc.
BIOS Version F3
BIOS Date 02/27/2008
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 2048 MBytes, Silicon Technology
Module 2 DDR2, PC2-6400 (400 MHz), 2048 MBytes, Silicon Technology
Module 3 DDR2, PC2-6400 (400 MHz), 2048 MBytes, Silicon Technology
Software
Windows Version Microsoft Windows XP x64 Professional Service Pack 2 (Build 3790)
DirectX Version 9.0c
Lupiron
1,711
Down Load and Run Core Temp, and list the VID of your Processor here, please? Since I haven't seen ya around! I hope its an OEM chip! Retail will more than likely be 1.3000 or higher, the worse ones, and that decides your starting voltage.
Knowing that decides your needed voltage for a given speed.
Where did you wanna over clock it to?
What type of cooling do you have, and if you would, please list the other components, like Vid card, Power supply, etc.
--Lupi
abidullah
18
Video Card : ATI Radeon X1900 CrossFire Edition
Cooling system : Gigabyte liquid cooler
Power Supply : 1000 watt
