Hello guys, i am new here!
recently my pc is having some problems, few days ago it started , i don't know how to explain this but i will try my best!
from last few days when i turn on my pc, it normally turns on, i can do my work as usual but it turns off automatically after a hour or half, and then it won't turn on at all, however after leaving it for 3-4 hours, when i turn on my pc again, it started normally so at first i thought this was a coincidence but it happened again, after 30-40 mins, it turned off automatically and it won't turn on! so i called a local repair guy who said my ram is faulty and i should change it! so i decided to go with his words and bought a new ram! but the problem is still there, i just couldn't find what is exactly my problem! i did the paper clip thing to check my psu and it's working normally!
today i noticed that in my bios settings! my "" cpu core voltage, +12V and +5V"" is way way higher than normal, i am sure that's it's not normal at all bcoz it's showing in red and is above the normal limits!
i think maybe it's my psu and not ram and motherboard!
so i am posting a pic here of my asus bios to know where exactly the problem can be!
View: http://imgur.com/gallery/SWnUfAa
i want to know whether it is due to my psu, motherboard or processor?
P. S- i don't know if there are any rules regarding posts here so i apologise for any mistakes
