[NEED URGENT HELP!] Is it enough power?
SkizzFX
16
Okay so I'm building a decent rig for christmas on a budget. I already have some parts that i can use and was woundering.
Can the thermaltake tr2 (non modular) 600w handle powering:
g.skill Ripjaw x series 8gb set
AMD Phenom II x4 965 black edition 3.4 ghz (im not over clocking it)
MSI 97a-G46 AM3+ AMD 970 sata 6gb/s
Nvidia Geforce 210 1gb ddr2 pcie 2.0
with
250gb 7200 rpm hard drive
500 gb 5400 rpm hard drive
Antec ice 100 case
and a dvd burner/player
Please let me know!
well like i want to upgrade to a 550 ti or a 560 ti later on thats why i ask and this will be my first actual build. thanks for the answer and i already have the 600 w psu thats why the rig is only gonna cost me 227.87
I ALREADY have the thermaltake it isn't bad tbh.
Also will it handle that system minus the 210 and with a 550 ti?
and im not over clocking until i have a 1300 watt psu and water coolingl.
I already have the 210 it isn't bad i can get pretty stable frame rates on a lot of games. but im saving for a 550 ti
Well the 550 ti doesn't use much power to begin with. It only requires a 400 watt as a minimum.
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-550ti/specifications
where with the 560ti it requires 500 watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-560ti/specifications
Honestly though when it comes down to it I would either wait till the 600 series goes on the cheap or maybe even look for the AMD cards. The 600 and 7000 series are a bit lighter on power then the 500 series.
1300 watt that might be borderline overkill if your running 6990's in crossfire.
