Question Need urgent help to lower the CPU voltage Ryzen 7950X3D
May 22, 2023
4
The BIOS version is 1415, but I have repeatedly noticed an increase in voltage above 1.30v. Very important, I have EXPO turned off and the RAM frequency is at 4800MHz
CPU SOC does not exceed 1.1v
VCORE CPU goes over 1.30v very often (goes up to 1.39v)
CPU VDDIO / MC - does not exceed 1.1v
Ryzen 7950X3D
RAM: CMH64GX5M2B6000Z40
Motherboard: ROG CROSSHAIR X670E HERO
you have two CCDs, one with X3D cache, which should be limited to 1.1v vcore and second CCD which operates with normal vcore voltage as non X3D CPU, that is up to 1.4v
Is everything okay with my CPU?
