Need Urgent Help
oops2001
173
Hi
I have two Sata hard disks
On one disk I have win7/winxpPro64
On second I have win2003server/winxpPro32
When I choose disk one from Boot Option menu (when the pc just starts and you press F10 to choose boot sequence)...everything works fine.
When I choose disk two, the system loads but my mouse and keyboard doesnt work as soon as it reaches the login menu ( happens to both the OSes in the second disk )
Please help I really need to work on my ERP softwares installed in second disk as it had costed me good amount of money and time.
thanksyou.
My mobo is inteldg45id.
Yes I can see files on the second drive/s when I boot from the first.
Now the windows Xp OS in the second drive is working but
windows 2003 server still not detecting ny USB ports so i cannot work with mouse and keyboard ( in safe mode also) 🙁??????
Any fixes please.Or any usb system files that i could paste from outside into the 2003 server OS...please tell.
thnks
FYI I got softwares / OSes installed on the second drive by some other guy using his PC.
yes aford10 all are good except windows 2003...should i try to get sp2 for it or get installed by someone else?
and one more question out of topic..
If i boot use the second hard disk through my e-sata port will there be any impact on speed or performance? ( if no, I think i will get an e-sata case..as it would be easier for me to root out any problems easily without having to open my cabinet again and again.)
