Need Urgent Help
golden-fries
5
Hello Everyone, i am a noob at pc building and i have managed to come to the very end of the build only to be stuck on a seemingly simple problem.
the case im using The Inwin 805 Infinity, the mirror hall effect rgb thing on the front wont turn on. i have found the corresponding plug but i cant seem to find anywhere that will actually power it on.
Maybe yours doesn’t have it, but some led objects require not only the power cord, but an rgb cord which allows the light to come in. My led fans needed a power cable and some sort of led cable plugged in for the fan to fully work.
