NEED URGENT HELP
cdenny1
40
I am literally looking at my newegg cart waiting to order, and then I see that ram is not refundable, so I better make sure its compatible, !
Will this ram
GeIL Black Dragon 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad Channel Kit Desktop Memory Model GB28GB6400C4QC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144240
Work in this motherboard?
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128376
Please help!
cdenny1
40
Thank you so much for the fast reply!
Believe it or not, thats the same ram that is in my other computer and it's great so far!
It is cheaper, and I didn't know I could just get two sets of 4gb. Too bad it more expensive in the end with $4 combined shipping :(
cdenny1
40
One more question, when I built a different computer 6 months ago, I got artic silver 5 and used it, but I think I used it improperly so now the e8400 runs hot. Should I apply the same stuff to stock heatsink that comes with the Phenom II X4 920, or no because its been a storage room that gets very cold. If the pre applied thermal paste works I'll prefer leave it on. Stock speed is 2.8ghz and I wouldnt want to up the voltage, but I would want to overclock a bit (up to 3.2 maybe).
cdenny1
40
xthekidx, my response was very ambiguous. I am getting the ram you mentioned, especially since I've been using a pair for 6 months without problems.
I'll take pictures of the process of the setup including pictures.
Thanks for all the help.
