Hi all,
I just finished building my new pc and am trying my hand at wireless for the first time. Here's what's going on:
I installed my WRT54G router using the setup wizard with no problems. I also changed the SSID from the default to another name and enabled WPA with a new assigned preshared key.
Next I installed my pci adapter on my second desktop and Win XP Pro (which I'm running on both) saw the card and installed it. However from there it isn't going according to the book)...
My second PC does not see any wireless network that I can connect to. I'm not sure what settings to mess with in the router so I thought I would post here for some help first. I'm also running Norton's Firewall on each pc and have tried disabling it but the other desktop still does not see the network. By the way both pcs also have the same workgroup name.
Any help would be much appreciated.
Thanks
Gary
Thanks
Gary
