Need your help guys
mruiz13
i have a VGN-CR240f thas has windows vista premiun im thinking to install Windows 7 but i dont know if the driver's for the vista will work i have checked and theres no driver's available (tell where to find them if you know) and yes im usin 32-bits now and of course i wanna install W7 with 64 bits. what do u recomend.
The large majority of Vista drivers are compatible with Windows 7.
To go from a 32 bit OS to a 64 bit OS, you'll need to do a clean install of the 64 bit OS. You can't do a regular upgrade.
Latest posts
