i was hoping maybe some of you could help me with advice on things to try here and ill post back with results.
my specs are athlon 1800+@1587.1 mhz, 138 fsb x11.5, chip is locked.
ak31 shuttle motherboard, with a via 266a chipset,
kingston hyper x 512 pc2700 ddr cas 2
geforce4 ti 4400 128 mb
550 watt antec true power psu.
well i have been trying to get my system fsb a little higher.
i have seen many cases of 150 + fsb and 190 in some cases.
lol i cant go any higher than 140 fsb at all.
i have tried slow settings, medium, fast, default, spd, host clock, etc.. it will not run at all after 140 fsb.
i have 3 volcanoe 9's , 1 on the northbridge, 1 huge one on a copper heat sync on the cpu and another on soutbridge, i have a fast rpm case side panel fan blowing on the memory which has a heat spreader, the case side is off and my a/c is blowing very cool air in there, the temps come up very low.
why wont this 1800+ go any higher than 140 fsb with good memory?
i have good power, memory and temps.
what should i set the ddr voltage too if anything other than default?
if anyone has specific settings i should use in the bios that would be awesome.
is it the mobo?
(ak31 shuttle via 266a chipset)
what should i try next?
do you think if i unlock the chip it will help?
i can only use 11, or 11.5 right now as multipliers i think.
any help would be greatly appreciated. thanx for reading
is it the mobo?
