1 15g Reputable Jul 15, 2014 32 0 4,540 Sep 3, 2014 #1 whenever i record gameplays with fraps it only records for 30 seconds can anyone help change it's settings
Solution Eduello Sep 3, 2014 That's because you have the trial version. Either buy the full version or use a different application like ShadowPlay (Nvidia only) or OBS.
Eduello Champion Mar 2, 2014 9,074 0 50,760 Sep 3, 2014 Solution #2 That's because you have the trial version. Either buy the full version or use a different application like ShadowPlay (Nvidia only) or OBS. Upvote 0 Downvote Solution
dovah-chan Honorable Feb 5, 2014 1,338 0 11,960 Sep 3, 2014 #3 fraps only uses directx and is not OpenGL compatible so it splits the video footage. Try a program such as bandicam instead or which is OpenGL compatible. Also fraps is fully uncompressed capture footage and will take a huge amount of disk space. Upvote 0 Downvote
1 15g Reputable Jul 15, 2014 32 0 4,540 Sep 3, 2014 #4 Eduello : That's because you have the trial version. Either buy the full version or use a different application like ShadowPlay (Nvidia only) or OBS. i'm an AMD user . my graphics card is r9 280x can u suggest me another software for recording gameplays Upvote 0 Downvote
Eduello Champion Mar 2, 2014 9,074 0 50,760 Sep 3, 2014 #5 15g : Eduello : That's because you have the trial version. Either buy the full version or use a different application like ShadowPlay (Nvidia only) or OBS. i'm an AMD user . my graphics card is r9 280x can u suggest me another software for recording gameplays OBS: https://obsproject.com/ Upvote 0 Downvote
