Needed Help with Graphic Card
LukasBerko
7
Hello i want buy graphic card for my desktop pc i want to ask if can i for PC SPEC
Intel Core 2 Duo E8400 @ 3.00GHz
Mother Board: iQon.ie 945GCMX-S2 (Socket 775)
RAM: 3.00GB Dual-Channel DDR2
Graphic: Intel 82945G Express Chipset
I wanna Buy ASUS GeForce GTX 750Ti GDDR5 2GB Graphics Card
Can i use GTX750 or any new graphic card? thanks for reply
What you can run mainly depends on your power supply brand and model and case size. Did you check if those will work and fit the card? The 750 Ti is a good card for it's power use, if you have the budget for it is a good one to get for a PSU under 350 or 400 watts. That card will also be OK to use if you upgrade the computer, which for gaming really should be done. A Core 2 Duo and 3 gig of RAM are low specs for newer games. You'd want a Q66xx or higher CPU and at least 4 gig of RAM, with 8 being ideal to run games on and pair with a 750 Ti. If you just get the video card, you may not quite get the results you want as games would be limited by the CPU and RAM.
thank you for your reply i have to check my power supply because i dont know how many watts i have at the moment i checked everything but not power supply
