Neo-Geo SNK help
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I turned my machine on yesterday and played a game of football, and turned
it off. I changed the game today and tried to play and the screen just
stays white, I can hear the sounds of the game but I can't see anything. I
put in another game it did the same so I went back to my football game, but
it didn't show up either.
Does anybody know what could be causing this? I looked in the back but I
wouldn't know what to look for anyway, even if its as small as a loose wire
I don't know where to start. Any help is appreciated.
Try cleaning and reseating the cart first.
"Mark and Jessica" <markjess24@earthlink.net> wrote in message
news😀jlWd.2058$CW2.1878@newsread3.news.atl.earthlink.net...
> I
> but
> wire
Oops, i should slow down and read better...
Could still be the cart contacts, but on the motherboard side rather than
the cart...
Could also have jostled the main harness loose.
> I
> but
> wire
Usually if there is sound I start looking for a problem in the monitor. Do
you have another Jamma game board. Plug it in and see what happens.
> I
> but
> wire
Usually when the cart connections go bad I tend to get playable garbage...
all white seems to imply something far more insideous (a simple bad a/d line
probably wouldn't do it).
> I
> but
> wire
