Nero-DVD RW problem
anon7mous
95
Hello
I'm using Pioneer DVD RW DVR-216D ATA device and it works fine until I try to burn something so I guess its a software problem. When I try to burn something on Nero 7 I get this error log:
PC
1C82-A0K5-19E5-MAAX-400E-CEEE-****
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <PIONEER DVD-RW DVR-216D>Version: 1.03 - HA 1 TA 5 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <DTSOFT BDROM >Version: 1.05 - HA 1 TA 3 - 7.10.1.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-216D D: CdRom5
DTSOFT BDROM E: CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1600MB (1639168kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.10.2011
ISO compilation
4:35:27 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
4:35:28 PM #2 Text 0 File Isodoc.cpp, Line 6666
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
4:35:28 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
4:35:28 PM #4 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
4:35:28 PM #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 716975 (159:19.50, 1400MB)
4:35:28 PM #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
4:35:28 PM #7 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: PIONEER DVD-RW DVR-216D, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
4:35:28 PM #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
4:35:28 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 716976 (716976) = #716976/159:19.51
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 716976 blocks [D: PIONEER DVD-RW DVR-216D]
4:35:30 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: PIONEER DVD-RW DVR-216D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1468366848, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 716976 | 0 | 0x00
716976 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
4:35:30 PM #11 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
4:35:30 PM #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
4:35:30 PM #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
4:35:30 PM #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
4:35:30 PM #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
4:35:30 PM #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 20x (27,700 KB/s)
4:35:30 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:35:31 PM #18 Text 0 File DVDR.cpp, Line 3225
Recording mode: Sequential Recording Mode for Multisession
4:35:31 PM #19 Text 0 File DVDR.cpp, Line 3381
Start write address at LBA 0
DVD high compatibility mode: Yes
4:35:31 PM #20 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom5: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x078c7d40: Len x648
4:35:31 PM #21 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
4:35:31 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
4:36:10 PM #23 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom5: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 03 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 73 03
Buffer x19220640: Len x10000
0x36 4A 06 34 04 96 12 C1 E0 3F 69 06 61 91 28 76
0x98 46 56 CD 1F B6 C3 2A 1B AB CF EE D5 A7 96 5E
0xEA 38 11 0E 9B 2F 4A 3D D9 A2 5D D4 ED C9 22 96
4:36:10 PM #24 CDR -1106 File Writer.cpp, Line 303
Power calibration error
4:36:10 PM #25 Phase 133 File dlgbrnst.cpp, Line 1762
Writing short lead-out
4:36:10 PM #26 SPTI -1176 File SCSIPassThrough.cpp, Line 179
CdRom5: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 01 02 00 00 03 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 72 04
4:36:10 PM #27 Text 0 File DVDR.cpp, Line 3783
EndDAO: Last written address was 767 (2FFh)Close Session/Border, function 2, track: 3, finalize disc: NO, ret: -1176
4:36:10 PM #28 CDR -1176 File WriterStatus.cpp, Line 162
Session fixation error
4:36:10 PM #29 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
4:36:10 PM #30 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 20x (27,700 KB/s)
4:36:10 PM #31 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
4:36:13 PM #32 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
4:36:13 PM #33 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
My system
Windows Vista
Motherboard Gigabyte ga-p31-s3g
3 GB RAM
5670 HD graphics card
Also for some reason when I go to my computer it shows 'CD Drive' not DvD RW as it should be. I tried reinstalling drivers and Nero but that didn't help.
Any suggestions are welcome.
Thank you in advance!
